is my system ok or i need to upgrade my ram or cpu first
highgrass
Commendable
Oct 14, 2016
22
cpu: core i3 6100 cpu
cooler: thermaltake contact 16 dual fan tower air cooler
motherboard: gigabyte ga-h110m-h
ram: hyperx black 8gb ddr4 2133ghz
gpu: msi rx 480 8gb gddr5
primary hardrive: 120gb kingston a400 ssd
storage hardisk: 1000gb toshiba 7200rpm
psu : evga 500w true rated 80+ bronze
im playing gta5 and other openworld games
If you are satisfied with current performance, then no upgrade is required obviously.Tthis is a pretty solid system overall.
But here is some insight:
- your GPU is probably the best part in your rig.
- CPU only has 2 cores with hyperthreading, which makes it a 4-thread CPU; games which require more threads (6, 8 or more) will be bottlenecked by the CPU. Others which use up to 4 threads should all work flawlessly.
- 8 GB of memory is OK, but 16GB is recommended for latest games. It all depends on which games you play. For some, 8GB is plenty. For most recent ones you will need 16GB.
- not an immediate issue, but 120GB SSD is quite small, especially if you install games to it. At least 250GB, preferably 500GB is today's norm.
im using my ssd for system like os. my 1tb is for installed games. i cant play gtav at veryhigh settings... and im getting low fps cant get it to 60fps. only 35 to 40 fps. my gtav is moded with enb some script and addons...
