is my system will be enough for 1440 gaming
thegameon
77
system:
asus rog mobo
still rockin i5 750 at 4.0ghz
12gb ram
750 hybrid drive+1tb hdd
2 gtx 670s 2gb
750watt pw
so the question is im gettin benq xl2730z and i already have xl2420t 120hz 3d
the new monitor is 1440 and the 24 inch one is 1080p, i always game at 1080p i might even use the new one at 1080 for some games.
the games i play are cs;go, assetto corsa, f1, battlefield sometimes, alien isolation, gta v, as u see wide varietyof games if the system struggles at 1440p ill go down do 1080. i know 2gb is somewhat not enough for 1440p but if i lower the settings a bit, you guys think ill be ok ?
im not goin to play on 2 monitors at once i will just use the 27 inch (1440) for gaming, the other one will just be for browsing watchin vids...
yeah it will do the 1440, with the sli setup, at leats for the games you play, newer ones you might have some trouble with such as fall out but even thouse you can run at 1080. enjoy your monitor.!
yea man thinking the same
