So, stock cooler for an Amd a3 3300
And a Radeon R7 240.
Just so confirm if the cooling is not enough because sometimes an intensive game would cause my system to just turn off, like someone pulled the plug. And then boots up like normal.
Event viewer shows the same error as one would unexpected force shutdown. "The system has rebooted without cleanly shutting down first, This error could be caused if the system stopped responding, crashed, or lost power unexpectedly"
I put this under cooling because when I open the case up and blast the inside with a stand fan prevents it from happening.
