Hi guys and TIA for your help. I've got an out of warranty Belkin 1200VA uninterruptible power supply. It stopped holding a charge, meaning with it unplugged while items are plugged into it, the items have no power. A UPS should provide power to items plugged into it. Often, the solution is simply to replace the battery. But before I order a new battery, I want to make sure such will fix it.
So I used a digital multimeter to measure the output voltage on the battery. I set the multimeter voltage to 200. Touching the multimeter probes to the pos and net battery contacts, I get a readout of 26.8.
The Battery is a Ritar RT1250 and the label says "12V 5.0AH/20HR Valve Regulated Rechargeable Battery. Constant Voltage Charge. Cycle Use 14.4-15V. Standby Use 13.6-13.8V. Initial Current less than 1.5A."
Is this battery good, meaning the UPS unit has gone bad? Or is the battery bad?
Leafgreen
Leafgreen
