Is my videocard going to work with this motherboard?
Witch121
Commendable
Oct 22, 2016
8
I have a Nvidia Geforce 730 2GB ddr3 videocard and i am afraid that it wont work with the motherboard i am planing to buy : Q35T-AM >.< ?????? Help me.
I believe you're talking about the GT 730, if that's so:
Yes it will, you can rest easy, the mobo has a 'PCI-Express x16' for your GPU so it's going to fit.
The GT 730 also take it's power directly from the mobo, so you won't have to plug anything off from the PSU to it either.
Just plug it in, install it's drivers and play.
Simple as that!
Hope to have helped.
Simple as that!
Really ? That is awesome ! I was not sure because i was looking at this site : http://www.pc-specs.com/gpu/Nvidia/700_Series/GeForce_GT_730/886/Compatible_Motherboards and in the Acer tab the Q35T-AM wasn't there ,so i pooped my pants. But thanks for the fast reply . Sorry that i forgot to write that i was talking about the Gt 730.
