Hi,
I have:
Corsair H80i V2 cooler
Intel i7 4790k
Phanteks P400A RGB with 3 stock fans.
Corsair radiator is mounted to exhaust through the back of the case, pipes at the bottom. I've set Corsair Link for testing to constant 100% fans speed and pump to performance mode . When I run Prime95 with blend test it keeps 60 degrees for up to 10 minutes, and than temperatures go up quite quick. It looks like when water reaches some temp it cannot keep CPU cool anymore. I reapplied thermal paste, and running without overclock. Is it normal behaviour? I have no experience with water cooling.
When Cores temp rise above to 80-90 degrees, link shows that water temp is around 34 Deg. When I play games CPU temps are about 55-60.
I have:
Intel i7 4790k
