[SOLVED] is myCPU compatable with MotherBoard? help.
Nov 8, 2018
5
I was wondering how to check or if anyone could help me on how to check if a CPU I'm interested in purchasing was compatible with my mother board of my system.
Specs. The CPU im interested in is the (intel 17 4790k)
Motherboard
Manufacturer ASUSTeK Computer INC.
Model M5A78L-M PLUS/USB3 (AM3R2)
Version Rev X.0x
(CURRENT CPU) Processor AMD FX(tm)-8300 Eight-Core Processor
Video Card NVIDIA GeForce GTX 1050
RAM 16 GB
Operating System Microsoft Windows 10 (build 17134), 64-bit
Just wanna run games good and Im preety sure my cpu is slowing down my games. Dont know much about comptuters any help would be appreciated
Your FX-8300 should be enough for your GTX 1050.
You should install MSI Afterburner and use the on-screen display to show CPU and GPU usage. If your GPU usage is maxed out at 99-100% while gaming, then you could benefit from a better GPU.
If you want a better CPU, you should get a new motherboard and CPU.
I recommend both a better CPU and GPU.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($159.99 @ Amazon)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard ($69.99 @ Amazon)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory ($69.99 @ Amazon)
Video Card: XFX - Radeon RX 580 4 GB GTS XXX...
No, you can't put an Intel CPU in an AMD motherboard, or vice versa.
Your CPU is not as fast as other, newer CPUs; however, your GPU is also rather low-end for modern gaming. I wouldn't be surprised if you could gain more performance from a better GPU.
What games are you playing?
Video Card: XFX - Radeon RX 580 4 GB GTS XXX Edition Video Card ($199.99 @ Amazon)
Total: $499.96
Generated by PCPartPicker 2018-11-08 23:07 EST-0500
My budget is 500% for upgrading my pc. would these parts improve my pc?
