[SOLVED] Is patriot signature premium better than patriot viper 4?
Feb 19, 2020
7
I'm building a £200 pc and there's a patriot signature premium 2666mhz 8gb 2×4gb ram for £39. But there's also a patriot viper 4 3000mhz 8gb 2×4gb ram for £38.26. Why is the patriot viper cheaper even though its frequency is higher? Is it more worse than the patriot signature? Which one should I buy?
link each kit or give the model of the kits in question. From what I just looked up on the Signature "Premium" CL19 at 2666MT/s is terrible and you shouldn't even consider it unless you are pinching every bit of budget for a new system. The 3000MT/s kit is probably CL16 and would be a better kit.
Feb 19, 2020
7
7
Are these your only options for memory kits? If so, get the Patriot Viper 4, because It's faster, has far better timings and it's cheaper.
I am on a really tight budget. Do you know any ram under £40 ($50USD) that is 2666mhz or higher? Which CL is good?
