Is RipjawsX 8GB DDR3 2133Mhz compatible with Asrock Z77 Extreme 4?
khatz
5
RipjawsX 8GB DDR3 2133Mhz (F3-17000CL9D-8GBXM)
I have bought this RAM yesterday and when I visited their website, the Asrock Z77 extreme 4 motherboard is not included in the qualified motherboard list. My question is, will this sticks work properly in this motherboard? If not, what will happen with my system if I still continue to use these?
Please advise.
Should be no problem at all, just make sure to configure settings in BIOS/EFI since the memory is much above standard. With the proper settings, your system should be fast and stable.
Thank you
GSKILL SUPPORT
Thanks! If I add another 2 sticks of the same model, would it be fine?
so...just "configure" the setting? Do what with them? what is a efi? I most likely will not being doing any of that because I have no clue what your talking about..but I got this same memory and motherboard. Will it work or not? is there a guide you can link. Please explain what you mean by "configure".. I hate googling a question just to get wayyy more confused and worried. What do I configure, where is it, what do I do with it when I find it, AND WILL THIS MOTHERBOARD WORK WITH THIS RAM OR NOT ?
