[SOLVED] Is RX 570 faster than the integrated GPU of Ryzen 5 3400g Vega 11 2020? Because the clock speed of Vega 11 is 200mhz faster than rx 570.
Jun 24, 2020
18
The Vega 11 is 1400mhz (max boost) while Rx 570 is 1270mhz( max boost). But RX 570 is 400mhz faster in terms of memery speed. Is it better off without RX 570 or should I buy a Nvidia graphics card?
You are confusing core and memory clocks with overall speed. Memory clocks aren't the same as memory bandwidth, and core clocks don't tell you how many cores you have.
The 570 is much faster than Vega 11 graphics. Check it out: https://gpu.userbenchmark.com/Compare/AMD-RX-Vega-11-Ryzen-iGPU-vs-AMD-RX-570/m401440vs3924
The 570 is an older card though, I'd get something newer and better. If I were you I'd get a GTX 1650 Super or a GTX 1660 Super depending on what you can afford.
Reactions: King_V
Ohhhhh ok, then I'll just buy GTX 1650 super then. Thanks for the advice.
also depends on ur budget...rx 570 is very cheap and is a blast fr its price...if u ask me increase u r budget and get ta 1660 ...dont buy 1650 super..performance is almost same.. or get a rx 580
The GPU hierarchy chart is a good reference to see how various video cards perform relative to each other.
Keep an eye out on prices, though - as a few people have already pointed out, sometimes a little bit more money will get you a MUCH better price/performance bargain.
What country are you buying in? What is your budget? And, most importantly, what is the brand and EXACT model of your power supply? If you're getting an add-in video card, a QUALITY power supply is essential - and quality is more than just wattage rating and 80-plus efficiency level.
