CPU will be fine, GPU will likely be problematic in more visually demanding games. You'll probably want to step up to a 1660S or higher since inconsistent performance in VR can easily cause motion sickness or other similar problems.
Is this a planned build or components you already own? 3800x is a rather high end CPU while the 1050 Ti is toward the lower end of GPUs. If this is a planned build, you should get a cheaper CPU and spend more for a better GPU and get a much better VR experience. Like an R5 3600 and RTX 2060
Edit: this is for US prices, not sure if prices will add up the same/similarly elsewhere
