is samsung b&w laser printer good for printing envelopes?
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I have need for a laser printer that will print 200-250 envelopes at a
time.
Has anyone reading this used any of the Samsung laser printers? They
appear to be price competitive, but I desire to know how efficient they
are for
envelope printing?
best,
Aaron
I have a Samsung ML1510 (Don't laugh) it's only an 'El Cheapo',
actually I was looking for a replacement for the dreaded Epson C62
and came across this at Dabbs Computers, Bolton, UK for about £48 -
and it proved to be a real work horse, I got this initially to make
printed circuit boards by using 'Toner Transfer paper' and does a
remarkable job infact the C62 is just ornament now as it does almost
everyhting.
It has already had two toner refill's, I found I could refill the
toner for about £6 instead of replacing the entire toner unit for
around £60.
Decide on the model and check the following and you can save a lot of
money by getting refills instead of toner cartridge unit, which
incidentally contains the drum unit, hence the expense..
http://www.refilltoner.com/samsungRefillCom.html
The site not only tells you the models that are refillable but
explains and shows how to do it.
This particular one does crease the envelopes slightly in one corner -
DON'T TAKE THIS AS SAYING THAT ALL OTHER MODELS ARE THE SAME, this is
after all an 'El Cheapo' but the text is crisp as can be expected, so
you really would need to check this point, I would expect a
reasonably priced printer be able to cope in this respect and not
have this problem, no doubt I'm gonna' get told to use laser
lables....!
Another thing before we get told it ain't a laser printer (as we know
them) it's actually a LED (light emitting diode) printer, a laser is
only polarised light afterall no matter what the light source, but is
usually at the red end of the light spectrum running into the
infra-red - akin to the laser unit in a CD/DVD player.
I only wished I bought it before the C62.....!
Cheers Davy
