Gateway decktop PC, would not power up at all. After some troubleshooting I cut the green wire to the 24 pin power supply connector and added a switch to ground, and between using that and the power switch I am able to start up/shut down the PC, and everything works fine. But, if I unplug the power supply from the wall for more than about 30 seconds and plug it back in, I can't get any power at all using the green wire or power switch, until I remove the 24 pin power connector from the motherboard momentarily, then it starts up/shuts down fine as long as the power supply remains plugged into the wall. Is there a signal on a wire other than the green
wire on the connector that can prevent the power supply from turning on? I don't want to replace the power supply or motherboard since the PC works fine when its on, but if there is a signal interfering with the power supply I could add another switch instead of having to open up the PC and remove and replace the connector.
