Is single fan graphics card enough?
Henry05
7
The EVGA GeForce GTX 1060 Gaming 6GB got really low on price so i would like to know: Will the single fan on this graphic card be enough in hot summer (30°C / 86°F)?
Well, I have one and if you don't mind the noise of the fan, it can be kept below 75c on full load with EVGA Precision. Again, it depends on the games you play.
Not the best card for hot climate and demanding games. You need good case ventilation for it. Also it is not recommend to overclock it. Overall this card will work on it's limits, so the lifespan is going to be effected.
But if you have a good case ventilation and this card is way cheaper than dual fan cards it may be worth a try. And yes it will be loud.
