Question Is something wrong with mobile after connecting wrong wire.
Apr 2, 2019
I accidentally connected a psu wire to the sys fan header in mobo, after switching on my sys it switched on for a sec then turned off , then I removed the psu wire from mobo and switched my sys again, it started working again but I am worried that if something happened to sys fan header or something else? Is my sys completely fine after doing that mistake?
hang-the-9
You will find out once you use the system for a while if it's fine or not. There is no way to know past a wild guess if anything was damaged if system is working now. How do you even plug in a PSU power cable to a fan header? They are very different connections.
Similar threads
