G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips,uk.comp.homebuilt,alt.comp.hardware,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc (More info?)
This page http://www.motherboardfaqs.com/article.php?17.255 says:
"The Thoroughbred "B" is simply a revised version of the
A core, with one major kick - speed! These chips feature
the usual optimizations on an instruction level, and
major modifications in the actual physical manufacturing
process."
From this I guess that a Thoroughbred-B running at, let's say, 1600
MHz is faster than the older Thoroughbred-A running at the same
1600 MHz.
But AMD rates both these processors as having the same "Intel-
equivalent" performance of 1900+. It's the same for other models
of T-Bred A and B.
I thought Throughbred B's are faster and cooler than the equivalent
Thoroughbred A's? Can someone please explain.
process."
1600 MHz.
of T-Bred A and B.
