I want to buy a new M.2. Samsung 950 Pro (256GB model). But my motherboard is a MSI GUARD-PRO ATX with 2 PCIe x16 slots. One being the video card obviously.
System Specs:
• CPU: Intel® Core™ i7-4790 3.60 GHz 8MB LGA1150
• HDD: (2) 3TB SATA-III 6.0Gb/s 64MB Cache 7200RPM
• SSD: 256GB ADATA SP600
• SSD: 512GB MX100
• HDD: 250 GB
• MEMORY: 16GB DDR3/1866MHz Dual Channel Memory (Corsair Vengeance)
• MOTHERBOARD: MSI GUARD-PRO ATX, 2 PCIe x16, 4 PCIe x1, 3 PCI, 1 x M.2, SATA 3
• OS: Microsoft® Windows 8.1 (64-bit Edition)
o Soon to be Microsoft® Windows 10 (64-bit Edition)
• VIDEO: AMD Radeon R9 270 2GB GDDR5 PCIe 3.0 x16 Video Card
o Soon to be a GTX 980ti
The M.2. Samsung 950 Pro needs a PCI-e Gen 3 x4. I only have the 2.0 x16 which correct me if I am wrong I can get an adapter for. (To be honest I am not sure my Motherboard can run the x16 at x8 but even if it can I hear that it will effect my graphics card a bit. This might be a huge problem for me depending on the amount. Does anyone know if it affects your GPU and if so how much?
So if I do plug it into my other x16 slot, will my GPU go down to x8 performance? I realize there's not huge performance drop between x8 and x16 for GPU, but am curious if that is the case or if I can get x4 on one slot and x16 on the other?
It will indeed reduce the video card to PCIe 3.0 x8 and I think its possible to make it a 2.0 x4 (as shown below from MSI website) would that slow my 950 Pro down and cause me to lose my 4 x1 slots bc I have an Ethernet card in one. The rest I don’t care.
• 1 x PCIe 3.0 x16 slot (PCI_E2, supports x16 speed)
• 1 x PCIe 2.0 x16 slot (PCI_E4, supports x4 speed)
• 4 x PCIe 2.0 x1 slots
Thank you for any help.
System Specs:
• SSD: 512GB MX100
• HDD: 250 GB
