Vic 40
Ambassador
Hard to recommend if budget isn't known. Build as is seems pretty solid when on a lower budget.
The psu is "okay", but if you can afford the next would that be better,
https://tweakers.net/pricewatch/1112041/bitfenix-formula-gold-550w.html
Could use this motherboard as well,
https://tweakers.net/pricewatch/1365592/asrock-b450m-pro4-f.html
If the wiring in your house is good could you look at these too for connectivity instead of the wifi adapter,
for a wifi adapter does this one seem better for not alot more,
https://tweakers.net/pricewatch/1478786/gigabyte-gc-wbax200.html
or just cheaper,
https://tweakers.net/pricewatch/372163/tp-link-archer-t4u.html
(if before V3 it comes with a cable you would be able to move it around,don't think that an usb3 cable costs much if it doesn't)
Vic 40
Ambassador
or just cheaper,
