Is the Gigabyte Technology Co., Ltd. 970A-UD3P compatible with 4-Pin PWM fans?
ProPlayerGR
595
42
19,040
Hey guys. A friend of mine wants to buy some corsair fans with 4-Pin PWM connectivity but he isn't sure about the compatibility. So can you tell me if these types of fans will be compatible with his motherboard? Thanks in advance.
He will buy a corsair obsidian 750d case and he wants to fill the entire case with fans. So he wants 2 fans for the watercooler at the rear (Corsair Hydro H80i v2), 2 120mm fans at the bottom of the case, 2 140mm fans on the top and 2 120mm on the front which come with the case. Take in account that all the fans he wants to buy have 4-Pin PWM connectivity (except from those that come with the case). That's all he wants. Thanks again.
He actually has a FX-8320 CPU and his motherboard and his GPU and his PSU have been damaged before and he had to change them. That's why he is so insecure. Eventually, he will buy 2 120mm fans for the bottom of the case. So can his motherboard power 2 120mm fans with 4-Pin PWM? Thanks again.
