[SOLVED] Is the Ryzen 5 1600af good for 1080p low settings at 144fps
kaib
Proper
Jun 16, 2020
263
I play mainly rocket league fortnite apex legends call of duty war zone
all on low sttings for high FPS
specs
Cpu Ryzen 5 1600af
Motherboard asrock b450m pro4
Ram Ripjaws v 2x8 3200mhz
Gpu Rx580 4gb
Ssd 850 evo 500gb
Case cooler master MB311L
poorbugger
467
63
4,790
It should be fine, the 1600af is basically a 2600. If you oced it, it will push more frames. The rx 580 will do a decent job as well. I have the same build except my gpu is a rx580 8gb. I can push 75fps constantly on maximum settings in warzone and apex so you should be good with low.
Reactions: kaib and RodroX
poorbugger
467
63
4,790
