Question Is the SODIMM slot and pinout for a Raspberry Pi CM3 the same as a standard SODIMM slot/pinout?
Dec 12, 2018
82
This is kind of based off my previous thread (https://forums.tomshardware.com/threads/can-you-use-a-raspberry-pi-cm3-in-a-regular-sodimm-slot-and-create-a-cluster.3468573/#post-20968000), but are the pinouts for a Raspberry Pi CM3 and a DDR2 SODDIMM pinout the same?
When examining the pinouts for the CM3 and for the DDR2 SODIMM slot, they appeared different, so I would like to know if they are compatible (so I can create and configure them to be coprocessors in a normal SODIMM slot of a laptop motherboard, please don't ask why).
TL;DR are the pinouts for the CM3 and a normal DDR2 SODIMM slot compatible?
Similar threads
