Is the Zotac GTX 970 4gb graphics card compatible with the NZXT G10 Water Cooling Bracket?
Elf_Knight
650
Hi guys!
I want to water cool my graphics card: The Zotac GTX 970 4gb GPU. However I want to cheat and use AIO Closed Loop liquid cooling. I can't afford the time or the money just yet on proper water cooling. I already have the Corsair H60 on my CPU (i5 4690k) and I want to put a similar cooler on my GPU since it gets really hot. So I was wondering if the bracket would fit. I tried the Corsair bracket but it was not compatible - the holes were too small. So I am afraid that it will not fit my GPU. Has anyone tried this? Can anyone confirm that it does or does not fit?
Many thanks in advance! :)
H60 shouldnt be too loud if you just reduce the fan speed. I had a h55 on the G10 and it wasnt loud at all with the fan at about 60% speed.
So it will definitely fit the Zotac GTX 970? And out of all of the AIO Coolers which one would you suggest for silence and best temps? The Corsair H60 is so loud! Many thanks! :)
the kraken x61/x41
