Is there a big difference between 3gb 1060 vs 6gb 1060?
rccanlas2
30
The price difference between 3gb and the 6gb version is 100$, is there a big difference between the two. Is it worth the 100$ additional price if i go with the 6gb version?
The vram you get in a card will be appropriate to the card.
VRAM has become a marketing issue.
My understanding is that vram is more of a performance issue than a functional issue.
A game needs to have most of the data in vram that it uses most of the time.
Somewhat like real ram.
If a game needs something not in vram, it needs to get it across the pcie boundary
hopefully from real ram and hopefully not from a hard drive.
It is not informative to know to what level the available vram is filled.
Possibly much of what is there is not needed.
What is not known is the rate of vram exchange.
Vram is managed by the Graphics card driver, and by the game. There may be differences in effectiveness between amd and nvidia cards.
And differences...
I don't plan to use beyond 1080p resolution. No 4k or anything. 1080p is fine. Will the vram matters?
And differences between games.
Here is an older performance test comparing 2gb with 4gb vram.
http://www.pugetsystems.com/labs/articles/Video-Card-Performance-2GB-vs-4GB-Memory-154/
Spoiler... not a significant difference.
A more current set of tests shows the same results:
http://www.techspot.com/review/1114-vram-comparison-test/page5.html
And... no game maker wants to limit their market by
requiring huge amounts of vram. The vram you see will be appropriate to the particular card.
The big difference is that the GTX1060 6gb has more cuda cores.
You should be alright then. You'll still get a little bit of an FPS drop because the 3GB only has 1152 cuda cores vs the 6GB 1280 CUDA cores, and the fact that you'll be butting up against the 3GB barrier quite often.
So yeah the 3GB should be fine.
