Is there a case that can fit 4x Titan X and water cooling?
jaa228
61
I'm wondering if there are any cases that will fit this build. If so which is the best for cooling?
CPU: i7-5960x
CPU Cooling: Swiftech H240x
GPU: 4 x EVGA GTX TITAN X Hydro Copper 12G-P4-2999-KR
MOBO: Asus x99-E WS
PSU: EVGA 220-T2-1600-X1
RAM: 8 x 16GB G SKILL Ripjaws 4 series DDR4 2800
Storage: 3 x SanDisk Extreme Pro 960GB with room for a couple 3.5" drives in the future
ODD: Pioneer BDR-209DBK
Also, if you see any issues with this build besides the cost or have any suggestions please advise.
Thank you.
is this already bought ? or planing to buy it ?
1- SilverStone Temjin TJ11
http://www.silverstonetek.com/product.php?pid=292
OR
2- Lian Li PC-D8000
http://www.lian-li.com/en/dt_portfolio/pc-d8000/
OR
3- Phanteks Enthoo Primo SE
http://phanteks.com/Enthoo-Primo-SE.html
OR
4- Corsair Obsidian Series 900D
http://www.corsair.com/en/obsidian-series-900d-super-tower-case
Those are your only options , remember you will need a case that can take 2 power supplies and 8 slots minimum for your setup.
UPDATE :
expensive but the best :
http://www.caselabs-store.com/pc-cases/
Custom built computer cases.
