Demorthus Distinguished Mar 2, 2014 383 1 18,965 Apr 5, 2014 #1 Is there a closed-loop water cooler I can buy for my GPU? This is a Newegg link of the make & model of it: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125488
Solution Demorthus Apr 6, 2014 Mac266 : compatibility check says it isnt. Compatibility on NZXT's site says GTX 780 but it doesn't mention any non-reference cards :/ My 780 is has a non-reference PCB.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Apr 5, 2014 #2 I've pondered the same thing for about a year, but I think this is the closest there is to a closed-loop system for a GPU: http://www.anandtech.com/show/7719/nzxt-kraken-g10-review-liquid-cooling-for-your-gpu Upvote 0 Downvote
Demorthus Distinguished Mar 2, 2014 383 1 18,965 Apr 6, 2014 #3 I've checked it out, but I don't beleive it's compatible with my card :/ Upvote 0 Downvote
Mac266 Honorable Mar 12, 2014 965 0 11,160 Apr 6, 2014 #4 compatibility check says it isnt. Upvote 0 Downvote
Demorthus Distinguished Mar 2, 2014 383 1 18,965 Apr 6, 2014 Solution #5 Mac266 : compatibility check says it isnt. Compatibility on NZXT's site says GTX 780 but it doesn't mention any non-reference cards :/ My 780 is has a non-reference PCB. Upvote 0 Downvote Solution
