Is there a fan controller for me?
ratsa
425
My new case has three 120mm fans.
Motherboard has one fan header.
PSU has only one spare SATA and one spare floppy connector.
Is there a fan controller that can power the three case fans? Preferably, it would occupy an expansion slot (no room on front of case).
ratsa
425
My Silverstone Grandia GD-05B case doesn't have a spare 5.25" external drive slot.
More importantly, I couldn't figure out what kind of power connection NZXT Sentrey 2 requires.
I have (i) one spare fan header on mobo, (ii) one spare SATA power cable and (iii) one spare floppy power cable. That is it!
Engima
711
25
The NZXT Sentry 2 uses one of your molex connectors coming from your PSU. Can you list what PSU you are using?
ratsa
425
The PSU is an Antec made specifically for Dell. It doesn't have a molex connector. It has 4 SATA connectors (I'm using 3 of them) and one floppy connector. I don't have budgeted for a replacement PSU.
Engima
711
25
One option I can think of if you don't have molex connectors is to buy splitters. I don't know of any fan connections that can come off of SATA connectors or IDE connectors (I'm pretty sure you have an IDE connection in order to connect to a floppy drive).
Try searching up 3 or 4 pin connection splitters and see what you like.
ratsa
425
The floppy connector I am referring to is the one called "Floppy drive power cable" here: http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Similar threads
