[SOLVED] Is there a heat reduction / fan quietness bonus to undervolting?
yaggaz
121
Just to be clear I won't overlock, my goal is always simply, cooler and more importantly, quieter. I build everything around how quiet I can get my rig.
My universal nvidia control panel FPS cap is 140 on my current 2080 at 1440p. I'm going to keep it at 140 on 1440p when I get my 3080 Hybrid. To me, smooth gaming is substantially increasing your -minimum- fps, NOT your maximum fps. Does it mean that a more powerful card will use less heat to reach the same performance? If no, will undervolting help any with heat?
It depends on the performance you want and how much power it takes to get there, but there's only so low a GPU can go before it's not stable or able to. For example, let's say the RTX 3080 gets 100 FPS in a game and the RTX 3060 Ti gets 60 FPS. You can probably limit the power of the RTX 3080 to match the 3060 Ti and possibly get better performance. However, if the...
okjak808
227
29
10,840
Undervolting will help with heat reduction but it can be unstable at times so you’re gonna have to be careful with that.
overtime cards can get more powerful while drawing less wattage take the 970 to 1070 for example.
but in your case the 2080 uses around 200 watts, and the 3080 you’re about to get uses around 300 watts so with the 3080 it might be a bit hotter and louder but that depends on what kind of 3080 you’re getting ex: MSI, EVGA etc.
this was done by research now sorry if I made a mistake.
yaggaz
121
Yes the evga 3080 Hybrid. It has a 240mm Radiator this time around. Initial reports from those on the forums who have even a 3090 Hybrid are getting 55c under load in Port Royal. I can't seem to get my current card under 65c no matter what I do.
It is worth noting you cant directly compare hybrid and conventional cooling methods in terms of noise.
Yes the hybrid card is running cooler, but is it going to be quieter in doing so? Chances are the answer is no. All you did was displace the location of the heat exchange.
It depends on the performance you want and how much power it takes to get there, but there's only so low a GPU can go before it's not stable or able to. For example, let's say the RTX 3080 gets 100 FPS in a game and the RTX 3060 Ti gets 60 FPS. You can probably limit the power of the RTX 3080 to match the 3060 Ti and possibly get better performance. However, if the RTX 3060 Ti can still achieve 60 FPS at say 60% power, the 3080 is not getting that close because most tools limit the power of the GPU down to about 50% (120W vs 160W at this point). Though if you cap the frequency using the VF curve (discussed later), you may be able to further reduce the RTX 3080's power consumption.
I also don't think video cards power gate anything except for shader clusters if the GPU is dead idle for several minutes. So there's always a minimum handicap a more powerful card will have because they'll have more things turned on even if they're not running as hard. Like the RTX 3080 has 10 VRAM chips whereas the 3060 Ti has 8. Those VRAM chips are never power gated, so the 3080 is always going to consume more power to keep its VRAM up than the 3060 Ti.
And keep in mind, minimum FPS is dictated by the CPU first, then the GPU.
On the subject of undervolting, the way to do it with GPUs is a bit more involved than with CPUs. Tools like MSI Afterburner or EVGA Precision offer you what's called VF (voltage/frequency) curve tuning. With this, you're telling the GPU what frequency you want for a given voltage. So you can either aim for a specific voltage and cap the GPU to the highest frequency it's stable at, or aim for a specific frequency and find the minimum voltage the GPU is happy with.
Or you can just power limit the card to whatever performance works for you. I've been doing that with one of the main games I play because performance doesn't improve at all past 75%, yet the card happily consumes more power.
Reactions: yaggaz
yaggaz
121
All I know is that originally my 2080 sounded like a jet engine to get it below 70. Once I put the AIO on it, I got to an average of 65c and am running all three fans (push/pull+VRM fan) on it in Quiet mode. Whisper quiet, you can barely even hear it now.
SHORTCIRCUT
44
Undervolting does help with temperature and power usage, by how much depends on how far you're willing to lower clock speeds.
There is a slight performance decrease, though depending on how conservative you go with undervolting, it could be 1-2 fps at most (but still having a good reduction in power and temps)
+ 3000 series' have really good undervolting capabilities
