Hi,
I'm building a SFF PC.
Motherboard : ASRock B550 mini-itx WIFI
CPU : Ryzen Pro 3900 (the non-X)
RAM : Patriot Viper DDR4 32GB (2x16GB) 3200MHz
Case : SilverStone SG05
GPU : MSI 1650 GTX 4GB LP
PSU : Thermaltake 550W
I'm looking for the best cooler that would not interfere with the RAM, M2 SSD or GPU.
In my shortlist, I've so far :
FYI, the 3900 is rated TDP 65W but tests under heavy load reported actual measurements of 88-90W.
Does it mean that any cooler rated 130-155W should be fine ?
Any other good options I have missed ?
Best regards,
K.
- Thermalright AXP90-X53 --> rated TDP 155W
- Scythe Shuriken Big 3 --> no TDP rating but could create issue and might not fit as nicely as the Thermalright AXP-X53, more reading needed
- id-cooling is-60 or id-cooling is-50 max --> both rated as TDP 130W
- Coolermaster G100M --> rated as TDP 130W but need to find a proper test and check how it fits on the motherboard
Best regards,
K.
