Is there a way for me to set up 2 monitors and 1 HDTV
Sam QS
190
I have a Sapphire R9 270x 4GB and it has 2 DVI+1 HDMI. I cannot for the life of me find out how to get all 3 running at the same time. Is there a way to do it? If anyone can help me out, that would be greatly appreciated!
Sam QS
190
Hm... The solution after digging around seemed to have fallen into the "active" display port. Apparently if you have 2 DVI and 1 HDMI port, you can only use either 2 DVI or 1 DVI and 1 HDMI, the third one will be disabled unless you have an "active" display port. I'll give it a try when my order comes in and update this page just in case anyone else in the future might run into the problem.
