[SOLVED] Is there a way to identify a computer case model?
Matthew0
One of my case fans is dying, and I need to switch it out. The sooner the better, as the grinding is getting quite annoying. However, my case is. . . odd. The fan in question is mounted to the front of the case, however, there is a weird metallic cover raised about an inch and a half off the front. A vent on the top and bottom allow air in and out. On the front is mostly open, with a tempered glass covering, allowing me to see in. The fan is screwed into the front of the case, so I can't get to them unless I figure out how to pull the front covering off, which I cannot seem to find the bolts that keep it in place.
I'm hoping to find some info on the manufactures site. Otherwise I'll take it in to the local tech shop and have them figure it out.
