is there a way to make graphics card run on full power even on battery ??
Elmehdi
8
when playing video games or running other demanding software the power supply on my laptop keeps disconnecting and reconnecting which causes the the GPU and CPU to keep switching from full power to normal ,
the power supply is 19.5v 4.7A while the laptop demand is 19.5v 7.7A,
can this be causing the problem ?
if so why did it start just recently ??
since i've been using the laptop for about a year now ,
is there a way to make the GPU runs on full power even on battery ??
please help me find a solution to this and thank you
laptop specs :
CPU
Intel Core i7 2670QM @ 2.20GHz 55 °C
Sandy Bridge 32nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Sony Corporation VAIO (N/A) 56 °C
Graphics
PnP-Monitor (Standard) (1920x1080@59Hz)
2047MB NVIDIA GeForce GT 540M (Sony) 54 °C
Storage
698GB Western Digital WDC WD7500BPVT-55HXZT3 (SATA) 27 °C
its written on the bottom , as for the model, its " VPCF23S1E "
do you think if i change the adapter it could fix the disconnecting and reconnecting power problem i'm having??
thank you both , i will replace the adapter ASAP and post the results , meanwhile thank you guys i really appreciate your help , cheers
Most likely. And even if it doesn't, you still need an adapter with the correct output anyway.
You're welcome.
Happy Holidays! 😀
