Is there a way to mount a fan without screws?
Gerard_14
Commendable
Dec 27, 2016
35
Hello,
I'm getting new hardware tomorrow and i thought that adding a fan might help the airflow. I want it to be a intake fan in the front in the free space shown in the pictures below. Only thing is I'm not sure how to mount it there, because there are no holes for screws there. The width is a little less than 150mm and the height should be no problem. It's a 140mm fan so I was wondering if there is a way to mount it there firmly without screws
pictures:
https://gyazo.com/fa10d111f92cf7eadf77138f9ab8331c
https://gyazo.com/8ed168ad238db2c4bbb834dc37ace24a
The case is a Coolermaster Cosmos 1000. It already has 3 exhaust and 1 intake, so I thought that adding another intake in the front would improve it
That might actually work pretty well, since there are gaps in the side. Thanks for the replies, I just noticed you answered my other thread aswell 😛
Haha, no problem. Good luck!
It looks like the only air intake issues you'll see are at the bottom there, where it looks like you have a solid piece of sheet metal. I would clean those removable mesh grates, and put a fan there, if you're alright with the inside looking pretty derpy
Alright, I was thinking about putting it there too, the bottom is for hard drives and stuff. No worries about it looking derpy though, because the case isn't transparent and I won't see any derps at all hehe
