[SOLVED] is there a way to permanently turn on Night Light?
Tac 25
Estimable
Jul 25, 2021
1,391
421
3,890
hi, I play the games on my sig 2 hrs before sleeping, and sometimes another 30 minutes or so in the morning before going to work. A gamer, so I need night Light to not get too much glare from the monitor. The monitor is set to Night Light in the evenings, but in the morning.. Night Light automatically turns off and I have to turn it on again.
question: is there an option where I could set Night Light to be permanently turned on in Windows 10?
monitor: 27 inch I-O DATA
You can also try this:
  1. Open the Action Center.
  2. Right-click on the Night Light toggle.
  3. Select “Go to Settings”:
  4. Adjust the color temperature by moving the slider. ...
  5. Turn off the Schedule if you wish the feature to stay active permanently:
Reactions: Tac 25
thanks again for the help and tips everyone. Edited first post to include the monitor.
@Old Molases - found it. Turning off schedule, then turning on Night Light keeps NL turned on.
@hotaru.hino - the monitor does have the option to reduce blue value. I've already set it to the lowest level. Also wearing anti-blue light glasses for more comfort.
