Question Is there a way to record in 1080p even if my monitor has a lower resolution?
Oct 10, 2021
19
Hi everyone. Sorry if it's not the best place to ask but I have a problem.
The thing is that I bought a new PC in order to play games and start a YouTube channel. However, at this moment I don't have money for a monitor and I'm gonna use an old one until I am able to buy something new. There is a problem though, the monitor resolution is 1680x1050 and I want to record in FULL HD. Is there a way to record in 1080p even if my monitor has a lower resolution? I don't mind if I can't see full hd while playing, cause obviously I can't add physical pixels but I wonder if I can record in a bigger resolution than my screen has, I want to have a good video quality.
Oct 10, 2021
19
What are the spces for your system (make/model of all installed components)? What application(s) will you use to record/capture video?
I use streamlabs to record. Those are my pc specs:
i3-10105
16gb ram 3000 (runs at 2666)
rx 560 4gb GDDR5
gigabyte h410M H V2
250gb ssd m.2
Jan 3, 2022
11
Hey bro, I hope I have understand your question. The screen recorder I'm using now is RecMaster. I find some settings about video. You can set the resolution, frame rate, encoder, output resolution of the video you record. The output resolution can be Same as computer screen, 1/2 computer screen, 1024768, 19201080, 19201200, 20481024, etc.
