Is there a way to slow down a fan connected to the power supply?
I'm not sure I'd do this. If the fan spins slower/quieter, you can cause it to overheat. An over heated PSU is NOT a good thing. Before doing this, I would look into replacing the fan with a better one. If you can find one that moves a lot of air, but is quieter, you have achieved what you wanted without having to increase temps.
I think he is talking about a case fan connected to a 4 pin molex on the power supply. If it is his power supply fan, then no, you don't want to do this.
I think i'm going to pick up a P5N-D wch has 3 fan connectors and a northbridge fan included not like my asrock with a burning NB ,I can't hold my hand on for more than 3 seconds.It only has 1 fan connector.
And another question. Can a overheated NB cause sttutering? ex: when I play crysis and I stand still my frame rates go from 40 to 75 and back in 2 seconds ,sometimes even lower.
Crysis problems could be a multitude of things. Outdated drivers, overheating, too big of monitor for the GPU, slow HD, bad lag, weak CPU/GPU. What ya told us isn't nearly specific enough. You need to find specific forums that deal with questions like that. There are 55 billion threads (more probably) dealing with game framerate issues. Google is your friend. Use it.
Drivers are up to date 180.43 , graphics are not weak , I have 2 8800 GTS 512 OC, and an E8400 3.4 GHZ wich is NOT overheating only 43°C under load.I play on a 1280x1024 screen
