J Jackr987 Distinguished Aug 4, 2013 274 1 18,795 Nov 19, 2017 #1 Every time I start my PC after a shutdown windows opens every program that I didn't close. Is there a way to revert it back to the old way?
Solution Colif Nov 20, 2017 I hadn't noticed this new feature, guess because I generally close everything before shutdown... You can try turning fast startup off, it should remove this feature, but if you use a hdd at boot it might be a little slower: https://www.tenforums.com/tutorials/4189-turn-off-fast-startup-windows-10-a.html
Colif Win 11 Master Jun 12, 2015 67,209 7,041 168,140 Nov 20, 2017 Solution #2 I hadn't noticed this new feature, guess because I generally close everything before shutdown... You can try turning fast startup off, it should remove this feature, but if you use a hdd at boot it might be a little slower: https://www.tenforums.com/tutorials/4189-turn-off-fast-startup-windows-10-a.html Upvote 0 Downvote Solution
