I disassembled a slim PC and it had a very nice turbine CPU fan (takes air in from the bottom and blows it out the side). It has a 3 pin connector for power.
From my understanding, The red wire is positive, while the black is negative. There is a white wire which I understand is the fans tach cable to communicate with the mobo.
Is there any way I can use this outside of a computer inside a 12V system? I'm working on a motorcycle project and this would be perfect for cooling in the small space I have.
I'm looking to either have it run full blast when I open a switch or hook it up with a dial to control the speed. Is any of this possible with this type of fan?
Thanks in advance for any help.
