Is there a way to wall mount asus mx239h?
kuba200104
Is there a way to wall mount asus mx239h? I know there are no vesa mounts at the back of this monitor, but is it possible to mod it so I can mount it on a wall.
Well seeing how most monitor stands use the 100mm x 100mm VESA mount I don't see any sort of conventional solution other than to maybe make a VESA mount. Like you could make one on a piece of plastic or wood and glue it onto the back of your monitor. That's the best way I can think of.
Yes, there's an adapter available to VESA mount it http://www.amazon.com/Adapter-Monitors-MX239H-MX259H-MX279H/dp/B00Z8WYROU/
