T tacanacy Distinguished Jan 16, 2013 91 0 18,710 Jan 29, 2017 #1 Is there a way to wall mount LG IPS277L? It's not VESA compatible. If I have to resort to glue, what type of glue will I need?
Solution USAFRet Jan 29, 2017 Well, there's this thing: https://www.newegg.com/Product/Product.aspx?Item=9SIA4FH3MJ5206 http://www.harrisworksystems.com/product-p/encloze.htm Look around. There are others. google for 'monitor mount no vesa'
13thmonkey Titan Jan 10, 2006 24,790 350 75,790 Jan 29, 2017 #2 with no vesa mount then you'll have to jury-rig something. A shelf perhaps? but there'll be no 'off the shelf' device if you excuse the pun. Upvote 0 Downvote
K kango69 Respectable Sep 3, 2016 320 0 1,960 Jan 29, 2017 #3 There is an adapter kit that will let you do it http://www.ebay.co.uk/itm/EZM-Adaptor-Kit-for-Most-Non-VESA-LCD-LED-Plasma-screens-003-0023-/182057827568 Or if you fancy a bit of DIY https://www.youtube.com/watch?v=3WX_zaZ1bcc Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,768 22,106 184,590 Jan 29, 2017 Solution #4 Well, there's this thing: https://www.newegg.com/Product/Product.aspx?Item=9SIA4FH3MJ5206 http://www.harrisworksystems.com/product-p/encloze.htm Look around. There are others. google for 'monitor mount no vesa' Upvote 0 Downvote Solution
