I just setup my first ever computer build, a gaming PC.
I'm using the fractal define r5 case, with a gigabyte z170x gaming 5 motherboard, an i7 6700k processor, a hyper eva 212 CPU cooler, and a gold evga 650 watt power supply.
I never really setup a video card or hard drive yet (still waiting on the hard drive and haven't ordered a video card yet), but I wanted to setup everything else and make sure that things are running smoothly.
I hooked it up and started the computer to see if it's working and also I wanted to check the bios because I know that will start work without a hard drive, and everything seems to be working properly, but I was just a bit concerned by some of the statistics in there and it may be nothing, but I just thought it would be a good idea to check with you guys first.
Running the PC for a couple minutes and it shows:
CPU Temp: 29C-31C
System Temp: 29C-31C
CPU Fan: 800RPM
I forget about the other two fans.. But I think the were around 400 RPM.
Now what was concerning was... the CPU fan and one of the other fans were randomly flashing to 0 RPM for a split second.
Do you guys think there is an issue there or would you be able to explain what's going on? I guess I'm just worried that maybe there is a power issue.. I'm not sure... by the way. I didn't use the fan controller up in the front panel of my case. I just plugged all the fans into the MB instead.
CPU Temp: 29C-31C
CPU Fan: 800RPM
