[SOLVED] Is there another good (portable) program than CrytalDiskInfo to monitor one's hard drives?
Aug 24, 2019
36
Hirens Boot CD has several SMART capable tools:
Thank you. Unbelievably I am not able to find the download link, sorry, where is it?
Would I have to make a boot drive first or could I just copy a program and use it?
I use Speccy. There is a portable version that you can keep on a flash drive and run on any windows pc to pull up much more in addition to SMART.
So the "Storage" section, I assume:
It does not give any warnings like CDI, doesn't it?
Aug 24, 2019
36
Many thanks!
Oops: "Old Versions" and "Since there are no official updates after November 2012, PE version is being developed by Hiren’s BootCD fans. ". That does not sound that good.
