Is there any problem with Zotac GTX 1050ti OC and DDR3 ram combination and also upgrading the graphics card ??
Undroy
12
I have a very old pc. I build this pc in 2010, now I just wanted to upgrade the graphics card to Zotac GeForce GTX 1050 Ti OC Edition ZT-P10510B-10L 4GB will it work ??
Currently I am running
Processor - AMD FX-6100 (stock cooling) (socket - AM3+)
Motherboars - GA-78LMT-S2PT
(https://www.gigabyte.com/Motherboard/GA-78LMT-S2PT-rev-31#ov)
Ram - DDR3 Kingston HyperX Fury 1866MHz 2*4GB (8gb)
Graphics card - AMD readon HD7750 1gb DDR5 (powercolor)
PSU - cooler master 550watt
HDD - 1TB* 2 (2TB) WD BLUE no SSD
Monitor - Dell 22" 1080p
Watch Dogs 2 Recommended Requirements
CPU: Intel Core i5 3470 @ 3.2 GHz, AMD FX 8120 @ 3.9 GHz
CPU SPEED: Info
RAM: 8 GB
OS: Windows 7 SP1, Windows 8.1, Windows 10 (64bit versions only)
VIDEO CARD: NVIDIA GeForce GTX 780 | AMD Radeon R9 290, with 3GB VRAM or better
Far Cry Primal Recommended Requirements
CPU: Intel Core i7-2600K | AMD FX-8350 or equivalent
CPU SPEED: Info
RAM: 8 GB
OS: Windows 7, Windows 8.1, Windows 10 (64-bit versions only)
VIDEO CARD: NVIDIA GeForce GTX 780 | AMD Radeon R9 280X or equivalent
In both of the above requirements the processor is your weak link. The same applies to editing as well. The problem is that your fx6100 will make the 1050ti underperform. But if you dont mind the bottleneck, then you can get...
I am not a huge gamer I want 1080p video editing and running some visual studio and android studio but can I play watch dogs 2, battlefield 1, farcry primal at high + 1080p res + 60fps ???
CPU SPEED: Info
RAM: 8 GB
CPU SPEED: Info
RAM: 8 GB
In both of the above requirements the processor is your weak link. The same applies to editing as well. The problem is that your fx6100 will make the 1050ti underperform. But if you dont mind the bottleneck, then you can get it. It wil still give you good enough performance, but just not optimal.
