Is there any problems with this PC build?
JLockhart
5
Case - Bit Fenix Neos. Dimensions - 185x429x470
Motherboard - MSI Z97-Gaming 5 ATX LGA1150
CPU - Intel i5 4960K
GPU - Nvidia GTX 750Ti
PSU - EVGA 600W Bronze PC Power Supply
Cooler - ARTCITC Freezer 13
Will it all fit inside the case and how well will it perform?
It will all fit and be fine. The only issue I see is if you wanted to upgrade to a high end GPU down the road... The case fits GPUs up to 11.5" and cards like the GTX 980 / R9 290x are closer to 12". As-is you will have no issues with the much shorter GTX 750 Ti. From a build perspective, you have a high end CPU (ready to be overclocked) and a motherboard that can do SLI / CF (multiple GPUs) paired with a mid level GPU. This is a little of a mismatch from a pure gaming perspective.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($214.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($27.99 @ NCIX US)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard ($124.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory ($43.77 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($85.00 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.05 @ SuperBiiz)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card ($114.99 @ SuperBiiz)
Case: BitFenix Neos Black ATX Mid Tower Case ($40.80 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($50.15 @ SuperBiiz)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($14.45 @ SuperBiiz)
Total: $762.18
...more of what I would recommend (non overclocking and single GPU)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($161.95 @ SuperBiiz)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard ($69.70 @ SuperBiiz)
Video Card: MSI GeForce GTX 960 2GB Video Card ($174.99 @ SuperBiiz)
Total: $685.86
What will you be using this PC for?
If you are gaming, you have a powerful unlocked CPU with a low end GPU. This is not balanced. It would be better to go with a locked 4590 + a good H series motherboard and put the money you save into a better GPU.
SAdams #2 build shown above is a good recommendation along these lines.
