Is there any way to add a 20pin USB 3 connector to a motherboard??
Maximilian Langer
14
I recently bought a relatively cheap itx motherboard. As a consequence there's only 1 9pin USB 2 and 1 20pin USB 3 connector on the motherboard and my case has 3 front panel USB's (2 x USB 3 and 1x USB 2). Now I don't want to leave one of these unplugged or unusable. I've heard of PCIE cards that add more connectors to the motherboard but my only PCIE slot is occupied by a graphics card. Does anybody have any other suggestions on how to add 1 20pin connector to the motherboard?? Thanks in advance
On the sixth picture of the case on newegg (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119286&cm_re=Elite_130-_-11-119-286-_-Product) it shows two cables coming out of the back of each USB 3.0 port, but they go together in one connector, which should fit in the 20-pin USB3 header on your motherboard. So as Someone Somewhere said, there's only one 20-pin cable, and you should be good to go.
Even on expensive mITX boards I'm only seeing one front USB 3.0 header (the one with 20 pins). My case and others I've looked at have a single cable supporting the two front USB 3.0 jacks. Does your case really have two separate 20-pin cables?
http://www.amazon.com/dp/B00F4J5D9K/ref=psdc_1048424_t3_B00H7OHW8A
http://www.amazon.com/Gigabyte-Intel-IWi-Fi-Bluetooth-Motherboards-GA-Z97N-WIFI/dp/B00K8HNGYW/ref=sr_1_8?ie=UTF8&qid=1437489334&sr=8-8&keywords=mitx&pebp=1437489454672&perid=0GSVNZB42JV4BNJHA6EF
