is there any way to connect 4 fans to the motherboard if it only has 3 chasis fan connectors?
shadybk
150
I am about to build my first computer and I didn't realize how many fan connectors my motherboard has. It has 1 cpu fan connector and 3 chasis fan connectors. The case I am using is a corsair 200r and it comes with 2 fans, one intake in the front and one exhaust in the back.
I wanted to add two more fans, one intake on the side and one exhaust at the top, but it doesn't look like I will be able to do that. Is there any way to connect 4 case fans to a motherboard that only has 3 case fan connectors? is it advised to do?
If I will only be able to connect one extra fan which one is more important? top exhaust or side intake?
I am not overclocking and I am using an intel i5-6500, but I just want the extra fans to be safe.
my motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157636&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
my case
http://www.corsair.com/en/carbide-series-200r-compact-atx-case
thanks in advance
would I be able to connect this straight into the 4 pin connector with the adapter it comes with?and then I would connect another one of these fans with the fans that come with the case using a splitter
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103060
http://www.microcenter.com/product/221360/TX3_Fan_Power_Splitter_Cable
