modern OS and CPU's will purposely try and reach the lowest power state that they can, so there shouldn't be anything to do. Check using GPU and CPU monitoring tools what the actual clock speeds are, you should be finding them close to idle for that kind of load, if not then change the reader that you are using, that'll make the biggest difference. Monitor temps, and fan speeds, they'll tell you what's going on.
