L lolwatrudoin Honorable Sep 26, 2013 16 0 10,510 Jan 1, 2014 #1 I know I could just unplug it from the motherboard, but it's a mini-itx case jam packed with components and I'd have to take out everything.
Solution USAFRet Jan 1, 2014 lolwatrudoin : No software to disable it for me or maybe something in the bios? Doubtful. It would probably take longer to root through the BIOS and find there is no setting for that, than to just open it and unplug that LED wire.
USAFRet Titan Moderator Mar 16, 2013 179,599 21,975 184,590 Jan 1, 2014 #2 Either tape over the light or open the case and unplug it. Upvote 0 Downvote
L lolwatrudoin Honorable Sep 26, 2013 16 0 10,510 Jan 1, 2014 #3 No software to disable it for me or maybe something in the bios? Upvote 0 Downvote
jjs0891 Honorable Dec 26, 2012 767 0 11,360 Jan 1, 2014 #4 What USAFRet means unplug the actual LED cable that connects to your motherboard. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,599 21,975 184,590 Jan 1, 2014 Solution #5 lolwatrudoin : No software to disable it for me or maybe something in the bios? Doubtful. It would probably take longer to root through the BIOS and find there is no setting for that, than to just open it and unplug that LED wire. Upvote 0 Downvote Solution
L lolwatrudoin Honorable Sep 26, 2013 16 0 10,510 Jan 1, 2014 #6 jjs0891 : What USAFRet means unplug the actual LED cable that connects to your motherboard. Yes I know what he meant. Upvote 0 Downvote
