I am trying to match it to the ps4 pro's gpu just for fun 😀Why are you trying to go this low? Just asking to understand what you are trying to accomplish.
A lot of people have successfully modded the BIOS on the RX 580. With a modded BIOS you can set the clock speed to anything you like. A major drawback of this is the chance the flash procedure will not succeed, resulting in a bricked GPU. I modded over half a dozen RX 400 and 500 series GPUs probably over 2 dozen times. I believe I bricked one at least twice. I was also able to successfully recover them through forced flashing via the command line interface, however that was a tricky process that required persistent trial and error attempts and secondary GPUs.I am trying to match it to the ps4 pro's gpu just for fun 😀
