[SOLVED] Is there anything missing or anything that would cause a problem?
So with all them changes, will there be a problem with case size or cable management or am I all good ?
I chose a PSU from the guy who also replied on this post.
https://pcpartpicker.com/list/QsrXrV
That is a solid build. You shouldn't have any issues with cable management. The Fractal Design Focus G is my go to "budget" case recommendation. The Seasonic Focus Plus Gold is a good choice on a PSU. It is a high quality PSU with the ability to do semi-fanless operation. That means that unless the power requirements are over a certain percentage, it will run without the fan spinning making it quieter.
Just made this build and was wondering if I'm missing any components or if any of the components are too overkill or not good enough for the rest of the system?
https://pcpartpicker.com/list/HtLngJ
Thanks, any replies are helpful
PSU isn't good.
3600MHz CL16 RAM is a waste of money. You are paying a large premium for 0-2% performance gain at best.
CPU cooler is too small for the 9700k. With a 125W max power draw you want a cooler that can dissipate around 190W of heat. The Hyper 212 is about a 125-140W cooler so at max draw the CPU will be in the 90C range which is too high.
Going 9th Gen is a waste of money overall. For a $35 extra dollars you can get the 10700k with is 8c/16t instead of 8c/8t. Or the 10700 for $35 cheaper. Alternatively the Ryzen 3700X $100 less than the 9700k and will have near equal gaming performance but better application performance.
For $100 more;
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($273.47 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Amazon)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard ($199.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory ($81.99 @ Newegg)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive ($69.95 @ Amazon)
Storage: Western Digital Blue 1 TB 2.5" Solid State Drive ($114.75 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card ($499.99 @ Best Buy)
Case: DIYPC Skyline-06 ATX Full Tower Case ($107.98 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($125.99 @ Best Buy)
Total: $1509.10
Generated by PCPartPicker 2020-06-26 12:27 EDT-0400
PSU isn't good.
Right okay so would this be a better build
https://pcpartpicker.com/list/H3vcn7
I excluded the power supply because I'd prefer an educated opinion on which one to choose i.e. from you 😀
Cheers
CPU Cooler: be quiet! Pure Rock 2 CPU Cooler ($49.40 @ B&H)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($59.99 @ Newegg)
Storage: Crucial P2 500 GB M.2-2280 NVME Solid State Drive ($64.98 @ Amazon)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive ($119.99 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card ($394.99 @ Newegg)
Case: DIYPC Skyline-06 ATX Full Tower Case ($109.93 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ B&H)
Total: $1402.73
Generated by PCPartPicker 2020-06-26 12:38 EDT-0400
Here is another option that ends up $5 cheaper than your original design but will game within about 5% of the second build.
Reactions: MarcT00
Cheers
While the Samsung 970's are great SSDs, they are overall way too expensive. You will get similar performance from the WD SN750, ADATA XPG SX8100 or XPG SX8200 Pro, Sabrent Rocket with all of them being $30 or more cheaper.
The Ryzen 3700X doesn't need a cooler as big as the Be Quiet Dark Rock Pro 4. With a max power draw of 88W the 250W cooler is definition of over kill. Most people use the included Wraith Prism cooler first and if it proves to be too loud then they change it. The Wraith Prism is a 125W cooler so if it is too loud going for something like the Be Quiest Pure Rock 2 is an upgrade.
Awesome, thanks for your help 😀
Reactions: jeremyj_83
