Is there enough room between my CPU cooler and Reservoir?
xaephod
446
I just moved my system from an old Cooler Master Cosmos 1000 to a cheap beauty. Wanted to get more airflow and the older case just doesn't have good flow.
Question: Do I need more space between the evo 212 and the reservoir for my R9 Fury X? There is only around 3 inches of space betweem them. Will the heat from the CPU heat up the GPU? Case has 5 fans, fan for the evo, and the fan for the GPU.
Is this ok, or will this cause heat issues with the GPU?
Thanks in advance.
You are probably alright, but there is only one way to be sure.
Test it.
